Mercedes C350e plug in hybrid Problem
Stefank
Reykjavik
2017 GLC 350e 4Matic 2.0L
Hi,I have a problem with my car Mercedes C350e plug in hybrid when drive like electric is perfect just in moment when change to petrol engine showing fault on cluster and them is no chance back again to electric drive till I stop car and start engine again them start in electric like must be.
(In march mercedes warranty was end)
Thank you
Yesterday I change starter and no changes
Hi, I am having the same problem with my GLC 350e and the starter has been replaced but no result. Was the problem fixed, please share the result it is highly appreciated?
Stefank
Reykjavik
I am having a similar display, same model and just out of warranty (i do have an extended warranty though). Getting similar battery management error U301700, starter motor P06E900, but also crankcase ventilation valve faulty (stored only) P052E71. Will let you know how I get on. In any event i do not regard the above as acceptable from Mercedes - there is obviously a design flaw here and they have an obligation to provide fit for purpose products. Having a car that is effectively irrepairable after only 3 years is not tenable. I would certainly make a lot of noise Did you get your car fixed in the end?
Hi, did you find a solution to your problem?
Regards Stefan
Stefank
Reykjavik
Thank you
Hi, did you find a solution to the problem?
Regards Stefan
C350e/2016/2000 c.c
Hi , Got same "malfunction" message on my mercedes c350e year 2016, driving in electric is perfect but as soon as it shift to the IC engine the message pop up. when scanned getting the fault U301700 permanently, and when IC engine starts getting the fault P06E900.
Error U301700 tips says the component "N82/2 (battery management system control unit faulty" or the software or the data set in the control unit is not up to date.
Did anyone updated the software to remedy this problem? Is this the root cause of the second fault code?
ajlsl600
france
This is service risk,so now my be change gearbox tomorrow engine and I will be pay for his not professional
Ok maybe you explain me how Mercedes service can not repair Mercedes car?
My view too... If mb trained guys can't fix mb car without change everything 1 by 1 then mb should pick up the bill until they have. they f built it. Op sure as h did not!!
Sums up modern car pretty well.
DSK
CLS 320 CDI, S350 Bluetec
It’s all part of the ‘keep them poor’ strategy. Sadly not many can see though it.
ajlsl600
france
T
Think i have sussed the wealthy can afford the multitude of possible dramas they will own the car 2,3 Yr then those that aspire to the marque come in, if we are fairly switched on we can manage to keep em going. This seems to be makers target, to make that as much hassle and as expensive as possible and thus many perfectly good motors consigned to the breakers and the cycle continues. Some off us get lucky, have the skills. So next step, make pts sealed ala stat n housing, many examples. And cost pts so repair completely ineffective cost wise, 2 headlights at £2000 and 3 k to fix timing chain does a good job of taking care of that. No.
Where's the green, carbon print, cost effectiveness for country or owner in that.
malcolm E53 AMG
^ Another good reason for leaving the EU Brussels are complicit in all this probably due to naivety or the fact that what Germany and France say goes the dieselgate fiasco confirms this and if it wasn’t for good old Uncle Joe nothing would have happened to expose it
ajlsl600
france
If u do EU research u will find worst by far members for ignoring EU regs. Germany and a country mile worse french. Ain't that interesting..
cloudygeco
New Registration
C350e
Hi if someone have charging problems you need to change this unit
Next week i go for update to fix the glitch with real time Clock because i'm getting storing and then Electric engine don't have Power
