Hi all,yesterday after replacing O ring on Intercooler-turbo pipe the bolt what bolts the pipe basically just snapped,I’m struggling to find a replacement,any suggestions what type of bolt/size is? Thanks
Not sure on the size of the bolt.
The fuel hose is going to give up on you soon ( see the cracks in it ) , think it’s the short one that goes to the filter.. they break up inside eventually and become loose and mushy and leak.
It will eventually leak and pee fuel everywhere, it’s the low pressure one from tank if I’m correct .. this one below https://www.ebay.co.uk/itm/11138592...Np2tH1cTaC&var=&widget_ver=artemis&media=COPY
