Erixx
Hello,
I have some vibrations in my ML270 that I cant get rid of.
Its not shaking but just slighty vibrating, when idling, everything inside if you put your hand on the interior. Its pretty clear when you grab the steering wheel or rest your hand on the gear lever.
When driving it changes with different rpm’s and if the engine is under load and I let go of the gas it almost goes away.
I have changed all the motor mounts and check rough idle in the Star Scanner program (all was fine)
I know it Will never become V12 smooth but this can’t be how they came from factory?
Is there any exhaust mount that goes bad? Or crankshaft dampener?
Car has 100k miles on it. Always been serviced and well kept.
