ml 270 cdi oil leak from inlet manifold w163
1meanmachine
I have the same issue. So following this thread with interest. Is there a guide on how to remove the swirl flaps.
dryerman
Herefordshire
CLK 320 2001 & ML 270 2003
Just to return to this thread. Oil leaking from inlet manifold. On my engine I can see the actuating rod/arm has disconnected from where it should be, I can push the arm backwards then it returns, so in what position does leave the flaps in or are they free to move about? Engine seems to run OK otherwise.
The spring pressure keeps the flaps open.
knowlep
England
ML270CDI W163 2000
Inlet manifold gaskets when doing mod on swirl flaps
Guys,
I've been reading up and I'm ready to do the manifold modification but I've studied loads of photos and it looks to me like the inlet gaskets themselves also fail to seal to the head properly as they look in some cases like they fail to protrude from the manifold itself. Do new gaskets solve this issue or should I put a bit of sealant behind them before I install them into the manifold to help this issue ?
om613
london
S202 C250TD, S123 240TD
Not needed with diesels.
I re-use them, unless there's obvious damage.
oigle
members.optusnet.com.au
Not strictly true. Sure, no vacuum to protect with a diesel but there is manifold boost to contain. If the rings are not sealing, get new ones. I wouldn't use sealant by choice.
Ian.
ajlsl600
france
This would also fit in to the new petrol engines being designed. there is no vacuum and runs like a diesel, and the flaps can control the mixture taking it down to the leanest burn possible something like 14 to 1 if I remember,,and getting 4 to 5 sparks per stroke. The same engine had no running gear,,all of the valves were controlled by solenoids
solenoids......
i cant wait for that to happen ,more ****** electric/electronics, if merc are lucky that stuff will just make it to the end of the warranty, i wont be getting involved in that. think i will buy a classic ford mexico or audi quattro. suspect my next decent car will be my last .
knowlep
England
ML270CDI W163 2000
Swirl flap housing question
I love my ML and I love this thread with the knowledge base of everyone.....
I have another burning question about the swirl flap removal....
I notice that the swirl flaps themselves fit inside their own "housing" in the manifold and on the mods I've seen this housing remains in the manifold when the manifold is refitted to the head.
My question is does the swirl flap actuating arm stop this housing from coming out of the manifold when it's fitted i.e. Is there a danger of the housing coming loose once the manifold is refitted or does the cylinder head prevent this. I also notice that these housings form a part of the gasket retaining surface as well so is this why they are left in ?
