Ml 270 cdi
Les manktelow
Ml 2002 2.7cdi
just bought a 2002 ml auto , a lot of car for the money . Great car apart from possible gearbox fault .
John Laidlaw
Wirral
Land Rover Discovery 4
Welcome. That’s a very popular vehicle on here so no doubt there will be several can pipe up with solutions
L
Les manktelow
Ml 2002 2.7cdi
Only had the ml two weeks , if you are in drive or reverse with your foot on the brake you get a vibration through the car and it will not reverse at all up a hill . Changes through the gears normally apart from that . No fault codes stored ( snap on scanner ) oil level fine according to dash test .
umblecumbuz
Wales and Gozo
... oil level fine according to dash test .
But presumably not the gearbox fluid level!
If it's auto, which most of these are, it'd be well worth a fluid and filter change, making sure the guy who does it knows the pocedure for getting the fluid level right.
L
Les manktelow
Ml 2002 2.7cdi
Waiting for a dip stick to arrive , so can check the level . The guy I bought it off reckoned the filter and oil had been changed . Probably just measured what they took out and filled back up with that amount . I read somewhere that initial fill up 7 to 7.5 ltrs . Hopefully will just be oil as you said .
7.5L is total capacity including the Torque converter , if he just drained the sump its around 3.5L .
When you get the dipstick , check the oil level on flat ground with the engine running (after a 20 Min drive) so the oil is hot , and the gearbox is in Park .
L
Les manktelow
Ml 2002 2.7cdi
Will let you know the outcome , when the dip stick eventually arrives .
Welcome!
They are pretty tough boxes, so likely easily rectified, even if not, there are loads about to grab parts from :)
L
Les manktelow
Ml 2002 2.7cdi
Hi all , eventually got the dip stick . Drove for half hour and checked the level after and it was about two litres over . Drained the oil out and it’s black . Obviously the previous owner had not changed the oil and filter like he said , just ordered a new filter so will try that once it arrives .
Using Fuchs Atf4134 (MB spec 236.14) will save you a few quid . Try eBay for the best prices
Taffy7hfa
Oxford
Hi Les, welcome to the forum, great trucks these, and I'm sure you have probably already noticed, dead easy to work on ;), most parts are relatively cheap too. good luck with diagnosing the gearbox fault.
L
Les manktelow
Ml 2002 2.7cdi
Hi all , drained out the gearbox oil and does not look good . Lots of gold coloured swarf ( if it was a manual I would say worn synchro ) . Have changed the oil and cleaned the filter out but still the same problem as before , looks like time for a second hand gearbox
harrycatcat
Sunny Chesterfield
2005 ML 2.7 CDi Auto
Oh dear, out of curiosity how many miles has the car done?
Sent from my SM-J510FN using Tapatalk
joderest
ML270 2003
oh, thats a real shame
The only trouble with buying a 2nd hand box is it could be the same, unless you can check the oil before buying.
Perhaps an Auto box shop could recondition for same sort of money as a 2nd hand box would cost.
I have a 2003 ML270, it has caused me a few headaches, but is running well now. They are ok to work on except for electrical bits, which are a bit "harry Potter" sometimes.
It tows like the trailer is not there, so lots of low down power.
I am sure you will get it right.
harrycatcat
Sunny Chesterfield
I like this advice, surely an "auto box shop" will have come across this before and would be able to give a near enough repair price for comparison.
umblecumbuz
Wales and Gozo
How do you 'clean the filter out'?
Did you follow the procedure that Wighty mentioned in his post? The car needs to be on level ground, and the engine needs to be running in order to accurately check the fluid level. If you have tried to do this any other way you will get a false reading.
L
Les manktelow
Ml 2002 2.7cdi
  • #20
It’s only done 143000
www.W140.co.uk&www.r129.co
