ML 270 - Electrics Issues - Wiring / Two Lights & A Window Aren't Working
MadeInMachines
Lancashire
ML270/1999/270 Diesel
Hi, I joined hoping someone with good Mercedes knowledge might be able to help with a few electrical problems I'm experiencing with my Mercedes ML 270 4x4 Diesel.
1) The front near side, side light isn't working - The problem doesn't seem to be the bulb or power problem. Perhaps the bulb holder causing the issue?
2) The rear drivers side break light is also not working.
3) The electric window on the drivers side - the motor works but the window doesn't go up at down.
What are the wiring colours for this car - does anyone have a wiring diagram of it?
Many thanks, any help much appreciated,
Pete
bignick
Airdrie
ml 2004 2.7 cdi
Hi
I had the same problem with window and was regulator was broke £60 eBay other problem was a faulty plug on light 1 wire was pushed up inside plug and dosnt connect
Hello and welcome, yes the window cassette has broken, I can send you the door card removal instructions.
It needs a voltmeter to check for the missing voltages for the lamps
MadeInMachines
Lancashire
Thanks for the helpful replies. Yes the door removal instructions would be great. Any idea about the light problems?
I need an Email address please that you can edit out later.
Re the lights it could be corroded contacts, it is just so hard without a little £4 multi meter, the trouble with electricity is that you can see nothing
MadeInMachines
Lancashire
I was looking for a PM option but doesn't seem to be one. My email is
p t j h @ h o t m a i l . co .u k (no spaces)
