ML 270cdi Turbo Replacement
jimson
Ml 270 CDI
So actually u suggest to replace the manifold because the face is already Brocken and posible leak from this chip off place the rubber is suck partially inside of cilynder area and leak open unseal space where the oil pass between engine and manifold
A what about the motor yesterday I check the new one and old one give me the same parameters on the digital multimeter
Do u know any option to be tested out of the vivhicle I already got the parts with VAT cost me £720 with stepper motor Regards Atanas
jimson
Ml 270 CDI
You don't indicate who you are or where you are situated. You obviously need to see a competent indy or MB dealer as you have little idea of what makes the engine go....
Don't go wasting money throwing a new turbo at it. It is normal to have oil in inlet manifold.
Get it properly assessed if you live somewhere that has suitable mechanics.
jimson
Ml 270 CDI
IMG_3088.JPG IMG_3089.JPG IMG_3090.JPG IMG_3091.JPG IMG_3092.JPG IMG_3093.JPG
V6Matty
Newark, Nottinghamshire
Replace the manifold, easiest option and go for one from MB the ones available from EPC are a good quality and don't come with all the ancillary parts
jimson
Ml 270 CDI
Well thank you I've bought already new from MB cost me £720 with the motor and gasket but today I saw on they specification details they have gasket between the EGR cooling and the exhaust pipe when I remove the manifold mine don't have such gasket is state N125 on drawing I'm confuse ??
