Ml box fluid
splitshift
central scotland, for now !
Clk 200 kompresser convertable, 2001 Citroen c2 Audi A3, jaguar xj6 and big scanias !
hi all, got a high mile ml350 petrol, love it , one day the clk convertible next the bus !!!! On the drivers side of engine bay there is a “ dipstick” type thing with the words, sod off workshop technician only( ok not quite !) am I correct in assuming this is the atf level dipstick ? If so can I treat it with usual hamfisted redneck disdain and use it to check oil without mb training or specialist knowledge? If it is, what atf should one use ? Box is good, all shifts are smooth and as should be, but prevention better than rebuilding in my eyes !! Cheers , Scott
I don't know your engine ...... I'd have thought it more likely to be engine oil :confused: as a great many auto boxes are 'sealed for life'
image.jpeg Does it look like this ..if so its ATF
Blimey .... a step forward by MB. :D
That's a 5g box , it depends if the op has an older ML , because the newer one will be 7g which is a fill from below gearbox with no dipstick .
ajlsl600
france
annother grand scheme, you can buy dipstick from benz or go to b and q and buy 3mtre of that springy flex curtain wire, i did and i use that, cant remember, someone on here told me how many mm up the oil oil should be and thats how i did it.
^ which can be bought off ebay for about 15 quid....
splitshift
All , yes older 350 petrol, pic to follow!
How many miles on it buddy ? . If you look at the pic I posted you will see a red tab in the middle of the black cap that means the oil and filter has been changed before (occasionally may have been changed after checking the level only ?? ) .
If the central tab is still black then it hasn't been done . Ideally should be done every 40k miles . It will cost about £200 for an Indy to change the ATF oil and filter .
The MB oil spec is 236.14 . I have used Fuchs Titan ATF 4134 which meets that spec .
splitshift
Oh dear !!! It’s currently 144000 but still has a black top !!! Job for next weekend then !!! Used to change xj oil and filters whenever I got em, so a filter and oil change imminent!
It’s 350 petrol,2003
Yep , well overdue . There is plenty of advice on this forums DIY section , and YouTube as well for the mb 722.6 5g gearbox . If you have done the XJ gearbox this will be a breeze :)
www.ckinsurance.co.uk
