ML Spare Wheel Carrier
seagrin
Gold Coast,Queensland,Australia
ML270CDI 2003
Hi all, i am looking for the spare wheel carrier for the ML series. i have a 163 and need to carry a real full size spare and i would like to find a second hand carrier.'these are the ones that sit up outside the rear of the vehicle and swing away when opning the rear tailgate - apparently! my ML is white if that has to be taken into consideration.
cheers
I would try Ebay
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Did you ML have the wheel carrier fitted from factory? if not then the ML has two versions of the rear spring, one for the ML with the carrier and one without.
My ML had the carrier fitted at factory but before I bought the car it had been removed, as a result the backend on mine stands 2 inches taller at than my mates ML so should you fit the carrier to an ML with the wrong springs fitted you might find the backend sits low.
jib
