ML270 heater fault
zac
Swansea, South Wales
Have been having a intermittent fault with the climate control/heaters not getting to full temp even when turned right up any suggestions?.
Mark A
Aberdeen
58 ML-320CDI.
I had a similar problem. I found that if I turned it right down to cold for a few mins & then back up to max, it starts to work.
Mark
Z
zac
we did that and it worked again?, does this re-set it, and has yours done it again? mine seem to be ok know.
Andy Wr
Stoke on Trent
My ML270 had a moment the one time when it would only blow cold until I stopped, turned off the engine and restarted the engine, it again blew hot.
I asked the question on what the ML set up was, if it was an electric valve but did not get much info so unsure on what the system comprises of.
Z
zac
Thanks! it looks like when you turn the heater control down to cold it seen's to re-set the climate control, haven't had any problem since.
