ML320 please help
Uncle Benz
West Sussex
Mainly Mercedes
An engine is basically an air pump. The volume of air drawn through the engine depends on its speed of rotation. The throttle butterfy governs how much air can go through. If the throttle is closed, the volume of air passing is reduced and a vacuum exists in the intake manifold. When the throttle is wide open the vacuum is practically zero. If a vacuum exists at wide open throttle you are restricting the performance of your engine. This is why induction kits were invented ;)
When I was at college my favourite lecturer swore by his vacuum gauge for diagnosing just about every possible engine fault. Proper legend. His name was Doug (oily) Wragg. Hope he is still alive.
Arudge
Cradley Heath
CLK200 2000 Kompressor
Don't think that can be right. Atmospheric pressure is 14.7psi which is roughly 30ins mercury so a perfect vacuum will be 30ins below atmospheric.
I had the gauge from work, which explains why it's clearly rubbish. I had no idea that perfect vacuum was one atmosphere / 30 inches of mercury. I've had a quick look on the net and the theory is beyond my understanding, i'll leave the clever stuff to the clever people.
I'll shut up now.
Uncle Benz
West Sussex
Mainly Mercedes
Vacuum doesnt draw fuel through the jets in a carburettor. A venturi is used to create a low pressure zone so the fuel is pushed through the jet by higher pressure in the float chamber ;)
It's why injected engines give more power than carburettor engines.
A carburettor requires a venturi (effectively a deliberate constriction in the inlet) in order to draw fuel into the engine. Remove the restriction and increase the airflow.
Arudge
Cradley Heath
It's not the way my mind see's it but i know your right. I understand the low pressure area created in the venturi is the velocity of the air passing over the jet orifice, and i see that it's the atmospheric pressure in the float bowl pushing the fuel forward to satisfy the vacuum created. But for whatever reason i see vacuum drawing rather than pressure pushing.
My friends say i'm special (needs).
benzmaester
benzmaester
ML W163 320
  • #48
That ma
that makes two of us then. Just started CAT removal ready for new.
benzmaester
benzmaester
ML W163 320
  • #49
This forum is full of Merc genius's. Uncle Benz, bang on, Cats were blocked and new ones sorted out the problem. Thanks to everyone for their advice.
Last night I had low coolant level light come on and go out and then the oil level light came on and went out. I checked these levels and they are fine. Today, the CEL came on but the car is running well. I will check codes when I get my code reader back as mine is on loan to a "mate".
tab & thanks again.
benzmaester
benzmaester
ML W163 320
  • #52
Yes thanks Andy, so am I. I really do appreciate all the help and suggestions from you, Lost Kiwi and Uncle Benz.
ATB
Sorry forgot to say, checked codes and reset misfire codes. CEL light out and not come on again. Car runs well. Just bled brakes so stops as well now
Sent from my SM-G930F using Tapatalk
