ML320 Pulley Disintergrating!!!
J.Smith
Surrey
2002 S320 - 1999 SLK230 Auto - 2001 SLK200 Manual
I have a 1999 ML320, I have noticed that one of the Pulleys (quite low down on the engine near the centre) is starting to fall apart! From what I can see, it has a thick rubber collar inbetween the outer & inner parts of the Pulley, it is this rubber part that has appeared to split and protrude.
Any advice as to whether it is a DIY job would be helpfull. Also, if I have to go to a mechanic, how would I describe the problem? What would happen if it completely fails whilst driving?
Many thanks in advance.
Ronnie.
panason1c
Somerset, UK
Mercedes ML270CDI, VW Polo 1.9tdi, BMW K1200RS
Hi Ronnie,
This is a known issue, you need to have the 'crankshaft pulley' (also known as a 'harmonic balancer') replaced immediately, this pulley will cause a lot of damage if it fails completely......have a look at this link from the USA for more info.....
http://www.benzworld.org/forums/w163-m-class/1175614-harmonic-balancer.html
Here is one of the posts from above link...
"Both of our 98 ML's had to have the harmonic balancer replaced, It's not pretty when one blows apart, it took out everything in front of it (radiator, fan, fan shroud, hoses, other pullies, etc...) and the oil pan".
J
J.Smith
Surrey
Thanks for the info guys. But to be sure we are talking about the same part, I have photographed the fault & circled it. Thanks again.
panason1c
Somerset, UK
Yep, that's the crankshaft pulley (harmonic balancer)
Fit a new serpentine belt at the same time
J
J.Smith
Surrey
Thanks Panasonic. Is it a job I can do on my own with normal tools, or does it need specialist fitting or any specialist tools? In the meantime should I not use the car? Cheers.
panason1c
Somerset, UK
I would advise you to have a good indie do the job for you, the pulley needs to be tightened to a very high torque.
Get it done asap!
pomm001
leicester
SL 500 R231 A clas W169
Ronnie.
Just looking at this post , i have heard of about 5 people i know all with different makes of vehicles all suffering with TV dampers coming apart, they can give very strange noises, one example was where the the ouy -of-balance damper put a 'harmonic' into the cam drive belt and for all the word you would have thought cam problems as they were being rattled by the damper. Maybe there has been a bad bach of glue
Number_Cruncher
1995 W124 E300D TE
Yes, it's an indication of how well these devices can absorb the torsional vibrations of the crank at troublesome engine speeds.
Either bad glue or similar manufacturing problem, or, perhaps it's just that these engines might have a particularly virulent crankshaft vibration problem, and these are just fatigue failures of pulleys which, when new, were absolutely AOK.
www.ckinsurance.co.uk
