My other car (Warning: Ford Content)
daveenty
The Frozen North :(
2019 AMG S Class Coupe
I thought it was about time I jotted a few ramblings down with regard to my new motor. I didn't want to clog the "UnMerc" thread up with it so thought I'd start a new one for it here. This way it can be either read or ignored without detracting from the main thread. Hope this is OK with the Mods?
I first looked at it, along with several other things, back in early July. I'd decided that I "needed" a pick up some time last year but didn't get round to doing anything about it for a few months for several reasons. I kept being drawn back to this one, mainly due to it's looks, the 1970 car being my favourite, though was made aware by the seller that it did want a few bits doing to it to make it something like roadworthy. I could have bought something up and running with everything done for a few grand more, but where's the fun in that?
It's a 1970 Ford Ranchero Squire, the Squire bit being the trim level though this has long since been removed by a previous owner. This was mainly wooden trim along the sides and tailgate. Also a plusher interior, again no longer in place. It originally had a 351ci (5.8 litre) engine with a 2 barrel carb, though this has been replaced by a 429ci (7.0 litre) with a large 750cfm 4 barrel Holley. I'm not over familiar with this particular engine as yet, though it certainly doesn't feel standard, as these engines were quite lazy though with bags of low down torque. This one feels quite cammy and has several noticeable extras fitted, including the aforementioned big carb, long tube headers and electronic ignition being the bits I've found so far. More tell-tale clues seem to be a C6 transmission which would usually be a C4 and a 9" locker rear end, both of which used to be fitted for racing back in the day. Along with the super shiny Centerline drag wheels it sort of gives a clue into the mindset of the last owner.
I decided to have it transported home as the rear tyres were exhibiting signs of age with lots of sidewall cracking and the brakes were interesting to say the least with a pedal that was either low or lower, so it seemed a safer way of getting it the 50 or so miles. It arrived on August 1st. The first job was getting the new tyres fitted. These came from My Tyres and were delivered to a garage of my choice. I've had a few runs in it since but I'm still experimenting with pressures as it skips about from the back end at the moment.
The brakes were a bit more involved unfortunately. The seller had suggested that it needed front pads, even going so far as to supplying a set with the car, along with top ball joints which he also reckoned were needed.
The old pads were removed but the pistons were really reluctant to return in the calipers, even with the bleed nipples undone. The rubber hoses were also perished and the master cylinder was spitting fluid out when the pedal was pressed. After checking the rears (drums) and finding that the cylinders were weeping slightly, I decided that the correct way would be to just replace the lot, which has now been done. The steering was also checked at this time as, if any parts were going to be needed, it would be cheaper to order them all in one hit to combine the postage costs. As mentioned earlier, a pair of top ball joints were supplied with the truck. It turned out that only one was needed, the play on the other side was due to worn bushes on the inboard end of the wishbone. Bottom ball joints were also required though it was strangely cheaper to buy the complete track control arm so this was done. All track rod ends were fine though a few boots are perished so they'll get replaced as and when. It's nice to have grease nipples on steering parts, especially when you can get to them all to pack them with grease.
An oil change has been done, along with the filter, though only after replacing the sump gasket which was weeping and dripping on my drive. Unfortunately, this seems to have only partially cured the problem, the next suspect for the drip being the rear main seal which are an apparent weak point on the big block Fords. It's another job on the list at the moment as I'm really not in the mood for lifting the engine again after the sump gasket replacement, I'm too old and tired for things like that.
There's loads more to be done, including loads of bodywork which has just been lightly started on, the interior which needs a full revamp and lots of little time consuming jobs like wipers/washers and things which, whilst working something like, need a bit of sorting.
I'll hopefully update this thread as and when I get more bits done but I'm not in a massive rush so it could be a while. :)
Just a couple of pics so far, more when I'm happier with the bodywork: -
EmilysDad
Bury Lancs
ML350
Very very nice Dave. I'm surprised I didn't hear you start up from my house! ;)
You suggested a rear seal might be weeping. Is it a lip seal? I only recently discovered that Jag V12s still used a rope seal up into the 70s
s5tuart
2003 R230 SL350
Very nice! I bet that's got a nice burble! :cool:
Looking good Dave, probably benefit from some weight in the back to keep traction
daveenty
daveenty
The Frozen North :(
Thank you people. it's definitely louder than the Scoop, though probably more subdued than that 850bhp Taxi which I used to run, especially when cold.
Having said that, long tube headers into a small cherry bomb type box on either side with the tailpipes exiting just under the front of the doors does make for an "interesting" noise.
You may when I get it into regular use Andy...
I have an option of a split (2 piece) rubber seal or a rope one, though not sure which one until I get it stripped to look at what's already in there. They interchanged around this year so a visual inspection is the only way to go unfortunately. Apparently leaking was a common and regular thing with them.
This will eventually be tried Russ, though still playing with pressures initially.
bladecrazy
bolton
tesla model 3 performance /honda cd175/w123 300d gertrude.
That looks great, the body looks mint.
AMGeed
Poole, Dorset
S204 C180K
Interesting project Dave. Something to keep you busy through the winter months in the garage.
DSK
CLS 320 CDI, S350 Bluetec
Congratulations, very impressive, very different but very cool, probably even more in current times. Enjoy every part of it! I certainly look forward to seeing and hearing more.
I bet you’re glad you don’t have to plug computers into itand pay anyone thousands in labour to scratch their heads and arses only to leave it broken….
We’ve had this era of doge chargers and other American muscle in providing the most interest from folks of all background and ages, far more than hot turbo Porsches and Astons and Bentleys do!
(My elderly neighbour, last year, was in the local press slagging off our entire residential area for people driving anything bigger than his Honda Jazz and having more than one car. The most anti car person one could come across. Guess what he bought 6 weeks ago….. a 1967 Ford Mustang fastback in weirded but fitting brown/bronze colour. (In addition to his new Honda Jazz). Love it!)
daveenty
daveenty
The Frozen North :(
Unfortunately it's a 20 footer, Good from Far/Far from Good.
I'm not really bothered though as long as it's solid. It needs a couple of bits welding but only cosmetically. It's 52 years old so deserves a few battle scars.
It's mostly in my mates garage Roger, he's got the space and a spare lift most of the time, so he's been volunteered to look after it. He's also younger and fitter than me so good to have for all those heavy/awkward jobs. Not only that but my garage is full of Mercedes. :D
That looks a fabulous beast Dave!
As you say, at 50 years old it's entitled to a few battle scars. I bet you'll have a great time sorting it out and getting it all ship shape.
Ron240
Fife
Sold - 2021 CLA 35 Premium.
That looks amazing, and I bet it sounds even better! :cool:
I had never heard of the Ford Ranchero but when I saw the photo it reminded me of an El Camino...and after doing some digging I found that this is not surprising. :D
daveenty
daveenty
The Frozen North :(
The Ranchero was introduced a couple of years before the Elk (1957 v 1959) but never seemed as popular nor sold as many. :( Having said that, the 59 El Camino was absolutely drop dead gorgeous and the 69 one was probably the best looking one they did. Chevy also managed to get their 454 rat motor sneaked into a few models, which made even the big block Ford like mine look under-powered. I think that the 1970 (mine) was the best looking Ranchero, with the 1969 one a close second, though the 1964 one is possibly now the most sought after owing to the James Bond connection (Oddjob collecting what's left of the Fairlane from the baling machine in the scrap yard)
This is one of the other things I'm having to cope with: -
These scratches were all over the bonnet and down to the metal in places. No idea what originally caused them but I would assume some form of reaction as there were an awful amount of layers here. Several coats of paint with thick sprayed on filler in between each of them. There was up to half an inch thickness in places so it's no real surprise that something has given up. I've now got all the scratches out but am struggling to bond the hood scoop back on at the moment, albeit just in the one spot so I may just cheat and use some JB Weld which I have kicking about somewhere.
I did try spraying it after my repairs but wasn't really happy with the result, mainly due to my cheating by using aerosols as I couldn't be bothered going out to buy a litre of paint. I also ran out of aerosol halfway through, so lesson learnt.
daveenty
daveenty
The Frozen North :(
  • #18
Bit of a quick update though not a great amount to report as real life keeps getting in the way. :(
I've been doing a few little bits before tackling the crank seal leak. The doors were one thing which was frustrating as they needed a really good slam to shut them. A bit of adjustment has helped here and they're now shutting smoothly, though the gaps between the doors and front wings are now huge so the wings will need a bit of fettling. The windows still need some adjustment as they're tending to wander a bit in their holders which, as they're frameless, is not really ideal.
There's been an issue with the gear selector ever since I've had the car. I think it was originally column mounted though this has been swapped out long ago for a floor mounted B & M Star Shifter, which is a ratchet shifter designed for drag racing. It's been an absolute nightmare to use so far though, either due to poor adjustment or wear and tear on the many moving parts. I'll see what I can do with it whilst the engine and box are out, though I'm currently looking for something simpler like a rod based shifter. I'm struggling at the moment to find something suitable, particularly at an affordable price, the nearest I've found so far is a generic shift mechanism which comes with several adaptors to fit most US transmissions including GM, Mopar and Ford. By the time the shipping's been factored in though I'm still looking at well over £250. Having said that, I may be able to sell the current B & M one, so will keep my fingers crossed on that.
A few other bits have been done, mainly minor stuff like wipers, washers and a bit of interior stuff, but they all add up and it's more ticks added to the "to do" list. This list is still pretty long unfortunately but we're getting there slowly.
I'm hoping to get the engine and box out next week as it's proving difficult to see exactly where the oil leak is. Not only that but it's going to be a lot easier to repair with it on the floor as opposed from trying to wrestle around it while it's in situ as it's such a big lump. This will give me the opportunity to give it a quick clean up and inspection before putting a bulk order in for all the parts it's going to devour.
My aim is to get it on the road for Xmas/New Year, just so I can have a quick run round in it to check more things out. Not holding my breath here though...
bladecrazy
bolton
you gotta love these old cars... i,m currently up to my neck in welding, bulkhead just finished and now taking wings off to inspect behind , always something to do!.
daveenty
daveenty
The Frozen North :(
  • #20
Well, my end of December deadline seems to be disappearing rapidly down the road due to yet another unexpected little problem, this time in the form of a blown head gasket. Pretty much out of the blue this but at least it's happened whilst it's still being worked on and not on some little road trip somewhere. At least it's brought forward the engine removal which was going to happen anyway, just not as urgently. The first suggestion of anything amiss was a reluctance to start as easily as it normally does from cold. After removing both heads it seems that number 3 cylinder has been benefiting from it's own water injection system as it's lovely and clean in there. It's also obviously contaminated the oil along with the brand new filter and everything else so a good internal clean up will be in order before it all goes back together.
A full rebuild gasket set has been ordered as the sump will be off again to replace the rear main seal, also a new thermostat has also been ordered along with a few other bits. All these extra gaskets and seals will (hopefully) be supplied with the kit. The sump pan itself is being replaced as it's been badly dented at some stage and we've got to thinking that this could be another potential source of a leak if it's not quite sealing correctly so it's another "while the engine's out" job.
It's now just a case of checking and cleaning things up ready for the new gaskets to go on which will hopefully be here by Monday, so it's a fingers crossed job that I have everything I need for it now. There will also be some steering bits being fitted, specifically the power steering control valve and a couple of it's pipes due to yet another leak. While under the front end, all the rubber boots for the track rod ends and drag link will be replaced as a couple are split.
I'm also currently also trying to get the exhaust sorted whilst the motor's out of the car. It has a bit of rot at the end of the headers with a few minor perforations. I'm just pleased that my local exhaust specialist have taken pity on me and are going to attempt to repair the headers by welding some new tube into them as they're ridiculously expensive to buy and difficult to source. One quote came in at over £1k for basic mild steel, with no guarantee that they'll fit so keeping the originals is pretty important.
I've now ordered the gear selector I've been searching for, A Mr Gasket Universal one, as the currently fitted B & M was proving to be too stubborn and, even with the transmission being disconnected, really stiff and awkward to shift. It seems that there's some wear in the ratchet mechanism so hopefully a new and more basic one will make life a bit easier.
I'd still like to get it up and running before Xmas as I want to try to get some bodywork done over the holiday period though it's not exactly my number one priority now, especially if it stays this cold.
