need help!!! e220 1995
saked e200 sedan
palmy
hi there was wondering if any body has ever had a propblem with there e220 what it is doing is making a funny rattle noise on start up and when you take off it sounds like its coming from the front suspension and it only makes the noise when u are still and the drive off not there when you are rolling ive just purchased the veichle and it also stalls if u start it without applying sum gas to it on start up whats up with that ?? any help would be appretiated.!! Kiwi boy lost with the technicals of the mercedes!!!:confused:
deejaybee
Surbiton, Surrey
Now - W210 E320cdi
Start by checking the throttle body
Hi, your problem with starting could be related to the throttle body. it may also be making the rattling noise you here as the stepper motor could be cycling back and forth if there is a problem here. Suggest you clean up the inside of the throttle body and make sure the flap can seat properly - you just need to remove the plastic air inlet ducting, there are detail instructions for this on the forum if you do a search.
If this does not work you will need to go through a detail step by step process of checking plugs, leads, water and air inlet sensors and then engine ecu. It is also worth getting the lambda sensor checked. If you are not inclined to have a go at this yourself you should take the car to a garage that can run a diagnostic check (but don't use a main dealer unless you are prepared for a big bill - not really worth it with an older vehicle).
Good luck.
Dave
luders79
London
W210 estate
Hello,
The rattle you may have could also be the drivebelt tensioner damper! This can be proved by appling pressure to each on the bushes on the damper in turn and see if it stops the noise!
As already said check a clean out the trottle body for stalling fault!
Good Luck
saked e200 sedan
palmy
thanks team problem solved was a loose catalatic converter cover duhhhhhhhhhhhhh thanks guys!!!!!!!
