need more power
faster_than_you
I live in Anna, Illinois
hello, my name is kylee. i am 16 and own a 1999 slk230...it has a 75 shot of nitrous, but other than that everything is stock. i am looking for ways to make her run faster at the track without damaging the car...i am currently running 8.7-8.9s
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Port and polish, oversize valves, blue print the engine, new crank, conrods, pistons, water injection, twin turbos, cat bypass, remapped ecu, new injectors, oversized throttle body.
Ow and remove anything that doesnt need to be there to save weight.
jib
BlackC55
South coast
C43
8.7 1/4 mile is very very very fast.
Are you sure.
F
faster_than_you
wondering if there is a way to turn off the traction control completely with the ASR button pushed...
wondering about raising the shift points and rev. limit
also, looking for larger crank pulley for my supercharger
F
faster_than_you
we have a chassis dyno here, and the nitrous kit is working perfectly with no signs of lean or detination..we are on this forum to find out if there are any electronic nerds that would be able to help us with tricking the ASR and raise the shift points
BlackC55
South coast
C43
You need a smaller pulley not a bigger one.
A smaller pulley will make it turn faster.
Parrot of Doom
Manchester
You'd be better off selling it and buying a TVR Cerbera instead.
F
faster_than_you
i'm sorry sir, i think you are incorrect. a larger pulley on the crankshaft will turn the supercharger faster, a smaller pulley on the supercharger will also make the supercharger turn faster but, due to an electric clutch on the supercharger i felt that there would be a greater chance to get a larger crank pulley
BlackC55
South coast
C43
Sorry read your post wrong.
Thats what I ment.
No need to call me Sir!
