Need to disable ignition on Sprinter
motovelo
Windy Plains Of Cheshire
www.moto-velo.co.uk
Still struggling on with fitting my replacement turbo (see other thread turbo installation help) and whilst I figure out where I can connect the wastegate actuator control pipe to (has to be somewhere on the intake manifold apparently but I'm struggling :() I've now learnt I need to prime the turbo with oil prior to starting it properly. So my dumb question is how do I disable the ignition on my van so the engine does not start when I crank it over? Easy enough on a petrol engine but I'm not so sure on a diesel??
Diesels are not my line but why not take out the fuse to the ECU.
Cnics
Worksop - UK
www.cnics.co.uk
This should work. Check in your manual, one of the fuses under the steering colum will stop the van starting. You'll get "Start Error" on the display but the engine will turn over.
This is a CDi engine right?
dava
The Toon
You should have put some into the oil feed pipe before you assembled it. Take off the pipe a put some in using an oil can.
