New to Mercedes
shadowsnypa
C220 CDI 2013 w204
Hi all
Im new to Mercedes, having driven BMW all my life, from E30s (3 series 84'), to G12s (7 series - 2018), i am about to inherit a w204 C220 CDI, in White, its a 2013 reg.
I have so many questions but will limit this initial post to what i need in a car, I will be using this car for my 60 mile daily commute, so I checked and it does have the essentials like cruise control, Bluetooth for tel and for music......the car has done around 55K miles and has been in the family for around 7 years.
The following I will be doing straight away:-
Will change front grill from silver to black (i see they are about £50 from fleabay) - how easy to remove and fit?
The car comes with 16" wheels, although the VIN when decoded states 19!! so I am looking for 18-19" wheels and tyres, I checked and the car is 5x112 bolt pattern and 8-8.5j - is 19 too big for this vehicle - will it rub against arches etc.... any pictures of recommendations (probably go darker colour on wheels- -grey or black) want to stay OEM though.
Is it worth buying the folding mirrors (i don't have these) and retrofitting I understand will need 2 new wing mirrors that can fold, a button module and coding. can anyone recommend someone who can code if it is worth it?
Is there anything to watch our for in this motor?
any recommended upgrades?
I thank you all in advance for any assistance.
shadowsnypa
C220 CDI 2013 w204
  • #2
Hi all
Dean Fletcher
Penrith, Cumbria
Mercedes E400
hello and welcome
im presuming you have the OM651 engine, common issues
water pump leaking
fuel filter housing leaking
rocker gasket and injector seal (Black Death)
inlet manifold sheered bolt
listen on cold start up for chain rattle
DPF sensor issues
with only 55k on the clock you might be ok for a while
other than that there not bad engines quite economical unless your into ULEZ, but rather noisy.
shadowsnypa
C220 CDI 2013 w204
hello and welcome
water pump leaking
DPF sensor issues
How do I find out what engine I have.
JBell
Torquey
C350 CDi Estate (GAD Edition)
To answer a few questions
The front Grill is easy to remove, 2 bolts on the top and the bottom slides back, videos on YouTube
Wheels wise 18" is no problem
Front 8Jx18 ET50 fitted with 225/40 R18 92Y
Rear 8.5x18" ET54 fitted with 255/35 R18 94Y
These are the OEM ones
I would check the Gearbox Service, if it hasn't had it done, then it needs it ASAP
Srdl
Hampshire
GLC43 AMG 2018 (X253)
You can use either of the following VIN decoders to find out more about your car.
PS - welcome!
Pritchsas
Wolverhampton
Mercedes c class sport
Front grill change is doable, upgrading to 18-19" wheels should work, and folding mirrors are a nice addition.
