Nexen tyres
JBell
Torquey
C350 CDi Estate (GAD Edition)
Well so what is a good budget tyre ? Get me right i can pay for top brand tyres but i dont see the reason if they turn out like the Avons i have on now that split after 4 years and still look like new .
Uniroyal RS3 / RS5, Falken FK510 or the Goodyear EfficientGrip all offer excellent value for money
A.J.
Norwich. UK
Thank you JBell i will keep that in mind for next tyre replacment.,
You have done well with the Avons at 4 years old. Traditionally they are of very soft rubber and enjoyed a short tread wear life. They used to be standard fitment to Rolls Royce and Bentley ! :)
A.J.
Norwich. UK
Ajd yes but i only did 3 000 miles on them from new ,. I dont think thats good at all do you ?
No, now you mention that it is pretty much in line with history then :rolleyes:
Ricardo_e220
Newcastle upon Tyne
R170 SLK230k 1999
3000 miles in 4 years... 4 years per set of tyres I’d not worry about that tbh
Most tyres are shot in 4 years if left out in the open the u/v makes them go hard
DREAMER NO2
W124 2.6E M103 1989
Ricaedo i know all about that,, but i wont buy expensive tyres to sit on my drive .The chepos will do . Would you remember years ago ? as long as the canvas was not showing then the tyres were classed as good . ha ha
McDonald
Surrey
SL500 2004
I was on the tarmac as MIGs flew in from the Czech Republic, to mark the 50th anniversary of D-Day. Young British pilots were excited to get a close look at Russian-built fighter planes. Their pilots were much admired. They could match the more sophisticated F15s without all the gizmos. The reality check was a glance at the tyres - you could see the canvas. A chorus went up, 'Should have gone to Qwik-fit.'
richlumb
GLC 350d
I had nexens fitted on the rears of my old w205 c class estate and they was twitchy I ended up swapping them to contis after a couple of thousand miles handling improved immediately
RhodieBill
Central South Coast. (Previously Out of Africa).
2001 W208 CLK320 182U ALMANDINE-BLACK METALLIC
I believe calling them a "Budget" tyre is a misnomer, as it right away gives the totally wrong impression. In fact calling anything "budget" is wrong because it all depends what your personal budget is - it could be £250 for a set or £800..... Both being a "budget".
I have used them personally and so have family and I would rather call them an inexpensive high performing Tyre that are equal in many regards to tyres costing up to twice as much!
Just a shame we don't get the full range in this country, namely the "SUR4g" But strictly a Summer Tyre. https://www.nexentireusa.com/tires/n_fera_sur4g
Rotorhead500
Very South Devon
Used to have a C63...
Age/UV hardening, coupled with lack of use... cracking will ensue on pretty much any brand.
They don't like standing still Capt Mainwaring!
Hi @joderest did you fit the Nexens? Would you recommend them?
I’ve got them on both cars now , can’t fault them at all , A rated in the wet and quiet . I’ve paid around £50 a corner about ayear ago . The E320cdi has massive torque at the rear and they are no problem at all .
A.J.
Norwich. UK
No........I Couldn't fault them either. Mine have done 14,000 miles now and show very little sign of wear and they are quiet. I would buy them again :)
joderest
ML270 2003
  • #37
I now have Nexen on the Lump, daughters mini cooper and wife's mini cooper D, all cars run with far less tyre noise over Goodyear and Mitchlin. Wife's Mini was £240 all in.
My other daughters Toyota Aygo will have them next month as well.
At this stage I cannot fault Nexen at the price point.
ash1212002
Coventry
clk 200 coupe kompressor auto 57 plate
I presume they are the Nexen N Fera SU1, is that correct?
Any views on Riken UHP, which are made by Michelin?
I've also been recommended Rotalla and blacklion tyres which generally have good reviews
