Nextbase 212 Dash Cam
John Laidlaw
Wirral
Land Rover Discovery 4
That’s a hell of a price JB!
No brainer as you say.
I’ve started (again) looking but I’m keen to get one with an integrated Speed camera detector built in (for some reason....)
JBell
JBell
Torquey
C350 CDi Estate (GAD Edition)
Exactly and with a case and 8GB card thrown in!!! I have a 12v socket in the Glove Box so it will plug in there
Headhurts
Norwich, Norfolk
Mercedes GLC300 2021
JBell
JBell
Torquey
Their prices on the rest of the NextBase range are also good,
https://www.ebay.co.uk/str/Velocity-Outlet/Nextbase-Car-Dash-Cameras/_i.html?_storecat=13706695010
I may be tempted to a DAB receiver soon
https://www.nextbase.com/en-gb/in-car-entertainment/dab-adapters/adapt-dab250/
but for this price
https://www.ebay.co.uk/itm/Nextbase...211155?hash=item466fba9b53:g:nuoAAOSwr5dbxFjb
That does look pretty good value, I might be tempted myself as I do miss the DAB+ I had in the W213. Not too keen on FM transmitters though, had an original iPod adaptor and was forever having to change the channel on it because of interference. Still it's a good enough price to give it a go.
Sigoodall
Southend on Sea
A207 E220/2013/Diesel
But how does it update the database of speed cameras? You'd be better off taking out a subscription to PocketGPSWorld and downloading their database onto a SD card, put that in the slot under your Command SATNAV then you'll see and hear the cameras pop up on the SATNAV screen rather than the DashCam screen which is better hidden from the driver's view anyway as it's too distracting.
John Laidlaw
Wirral
Not 100% on this technology to be honest . Does the PocketGPSworld system cover just known/reported camera locations or is it real time detection?
JBell
JBell
Torquey
For £40 against £500 for the MB unit it is worth a try
Capra
Gloucestershire
W204 2013 C350 CDI Pan roof
Great post. I've also been looking at dash cams. Thanks.
Sigoodall
Southend on Sea
None of the Dash Cams that I've looked at have real time detection. Even Road Angel sell separate devices for Dash Cam and speed camera detection. The Dash Cam detectors all appear to have a subscription service for their camera locations just as PocketGPSWorld does. I use PocketGPSWorld, the advantage over a dash cam speed camera system is that the warnings come on the bigger SATNAV screen which is at eye level and not on a small 3" screen which may well be hidden behind the mirror and the updates are weekly.
A family member has a new Ford which has a system that uses a combination of GPS and a forward facing camera to "read" speed limits and there's even an option to switch on a speed limiter to stop you going over the current limit, he claims this works on variable speed motorways too. I think that's a step too far! :(
davemercedes
Glos
I think he's visiting the future... with driver-less cars just around the corner I can see that within five years the do-gooders will be talking up enforced speed control. By that time you may as well have some shut-eye travelling 100 miles on the motorway because it will be so utterly boring. And if you dare to override the enforced limiter and get caught you'll probably be locked away (unless you can afford to use "Mr Loophole" in court!).
John Laidlaw
Wirral
I have this on the XC90, as you say it can pretty much completely take over!
keefysher
Hampshire
W166 GLE350AMG Line 3.0 2017. BMW Z3 2.8 1998.
Mecedes call it Traffic Sign Assist and Active Speed Limit Assist. Add in Distance Pilot, Active Lane Assist and Blind Spot Assist; switch the sat nav on and the car drives itself. You soon get used to it. The only thing I find is the car brakes later and harsher than with human control. Brilliant bits of tech that almost make driving bearable again. :D:D
Capra
Gloucestershire
So all you do is steer whilst on a long motorway drive? Never driven a tech car before.
Srdl
Hampshire
GLC43 AMG 2018 (X253)
That’s exactly what I did with my E Coupe - very easy to fit across the top, behind the A pillar trim, down the door trim and through into the glove box behind the end dash trim. Simples and all wiring hidden.
keefysher
Hampshire
Technically yes officer. Every 7 miles the dashboard will tell you to hold the steering wheel ;) on a test track motorway of course :D
John Laidlaw
Wirral
Exactly right Andy!
When I take the XC90 up North it really does destress the long boring journey. Actually it brakes smoothly.
In Volvo world it’s pilot assist plus and as said before you can even set it to obey the speeds...2 very different cars I have!
Capra
Gloucestershire
Wow, that is impressive. Looks how behind the times I am, and I'm only 44 years old on Sunday! (that's starting to sound old now)
Tel: 020 8863 9233
