No crank, fan runs at full speed, CLK320 2001
EPMB
CLK320, 2001
Thread Starter
CLK320
Engine won't crank, cooling fan runs
CLK320, will not crank and the fan runs at full speed. Replaced the k40 relay box with a genuine merc part. Touched a couple of the pins and the motor cranked so figure it is not a starter motor issue. Can't hear the fuel pump go. Possibly unrelated is that the temp and gear LCD on the dashbaord are pixilated, i.e. not reporting correctly. Have a hunch the ECU may not be getting power or the ECU has failed. Previous owner said that a wire to the fuel pump was replaced, which makes no sense, but can't get greater clarity. Any suggestions? How could I test to see if the ECU gets power?
E
EPMB
CLK320, 2001
  • #2
Additional info: When I cranked the engine (by connecting the two pins) for a quite a few seconds the fan stopped. I am guessing the ECU detected engine movement via the crank position sensor and sent that message to the fan - does the CPS report direct to the ECU or does it also report to some other electronic bit which then activates the fan?
00slk
Cambridgeshire UK
Any water around the main ECU........sorry, I'm an R230 owner :rolleyes:
E
EPMB
CLK320, 2001
No. Not that I can see.
Mr Greedy
Leicestershire
E350/2011/OM642 265bhp
Does this car have any fault codes stored? Or is this model too old?
E
EPMB
CLK320, 2001
We have not managed to get it to the repair shop and I don't have a code reader.
