No5 Injector blowing on 03 CLK 270cdi
Baldmechanic
Wales
CLK 270, Landcruiser 4.5, VW T4 2.5.
Hi all, searched forum on this problem but came up blank, so here goes.
Wife came home today in clk complaining of diesel smell when blowers are on, so she parked up and let the vehicle cool, i popped out about an hour later, took the both engine covers off and could see slight dampness at No5 injector base, after thoroughly cleaning around the injector and running vehicle, it seems to be the injector seal that is leaking leaking. now is there anything i should look out for when attempting this job, i have no injector puller as yet, i am going to get a new seal, clamp and stretch bolt tomorrow, and attempt job on weekend, one thing i will say there is no black death around the injector base as its just started leaking (not chuffing). my plan is
  1. To remove the injector pipe from the fuel rail to injector
  2. undo torx hold down bolt
  3. remove injector clamp
  4. try and gently turn injector left and right and gently use pulling motion
  5. remove injector
  6. remove copper sealing washer
  7. clean seat
  8. anneal new copper washer
  9. refit all
  10. fingers crossed all will be well, but i doubt it lol
Baldy
om613
london
S202 C250TD, S123 240TD
Yes, it'll probably come out easily just by twisting if there's no B.D. present.
No need to anneal new copper.
On mine, the clamp bolt torque was 8 Nm, then 2 x 90 degrees.
star
Reading
Smart + others :)
Make sure the seats are clean and not burnt, make sure the bolt hole is clear of debris as you can punch a hole onto the water jacket when doing up bolt.
Baldmechanic
Baldmechanic
Wales
cheers Om613 :)
Baldmechanic
Baldmechanic
Wales
Thanks star, i plan to cover the 8mm hole while i work then clean with some carb cleaner and straw, before i refit the torx bolt, i have a inspection camera to check out the seats, lets hope the seats are ok.
star
Reading
Smart + others :)
We reface seat and injector but if it's not been blowing for long, it should be ok. Check side of injector for splitting too. No need for camera, torch is fine.
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
As above ensure both seats are clean and the bolt hole is clean too.
Before you start the job, go for a spin and get the engine HOT. Just remember to watch where you put your hands when you start the job :)
If you want to make it easier next time (if there is a need), use MB's 'special grease', not cheap but does the job
Baldmechanic
Baldmechanic
Wales
copper slip any good?
om613
london
Nope.
When I did mine, I found that some enterprising individual on ebay was selling tiny (20g or something) pots of white/grey ceramic grease very cheaply. Enough for about 20 injectors and glow plugs.
I don't think it was bread sauce...
Baldmechanic
Baldmechanic
Wales
Nope.
ordered grease this morning....Thanks :)
Mark A
Aberdeen
58 ML-320CDI.
As per Bob, get things nice and hot before you start, makes a huge difference.
Baldmechanic
Baldmechanic
Wales
Well the job is done and all ok, thank you for all your invaluable advice :), the only problem i had was getting the actual copper seal out, in the end i used a brickies wall tie, cut it and turned the end to act like a pick, worked a treat, the injector came out lovely as prescribed :), put all back together started vehicle, one slight misfire and then all ok, again thank you all :)
abazem
Islamabad
Mercedes E270 cdi /2004/OM647
Congrats. I am presuming that this is same engine OM 647 which is used in E270 CDI.
Did you take any pictures while doing this job and how much did it cost you to do this job. I would be grateful if you could provide the vendor info from where you ordered the parts.
Baldmechanic
Baldmechanic
Wales
Hi Abezam i purchased kit from ebay, i didnt take any pictures as when i did the job it was outside and very wet, the seelr on ebay his id is :
ianpts123
hope that helps
make sure you get engine hot before trying to remove injector, i gently worked it back and fore and it came out a treat
Baldmechanic
Baldmechanic
Wales
NOOO!! Do not use copper slip. There is good reasons why there is a special grease. Copper slip will melt.
steve i didnt i used the correct grease that came with the kit :)
om613
london
ianpts123
hope that helps
Top seller for ersatz MB patterns.
Also KMS on Ebay.
Used both many times.
Baldmechanic
Baldmechanic
Wales
  • #20
I Apologise steve, that was supposed to say i didnt use the copper slip, i used the correct grease that came with the kit
