Nox Sensor / AdBlue Issues 2016 Mercedes/205.204
Mercmebaby
Shammy1870!!
Hi all, I have a 2016 Mercedes/205.204 - C 220 BlueTEC Wagon/C 200 d Wagon which had a recall to update the diesel software back in 2020 by the previous owner and need some advice with regard to the following issues.
I’ll be replacing the Nox Sensor, however, I’ve been told that a mk3 nox sensor needs to be installed as this will stop the EML returning. Can anyone advise what mk number is the current Nox sensor I have ( image attached)
Once the Nox Sensor has been changed will or should this solve the AdBlue fault, as it’s saying engine will not start after 425miles.
Current DTC’s
•P13DF09
The AdBlue(R) system has a malfunction. There is a component fault.
CURRENT and STORED
P1BC300 Additional fault freeze frame data for fault analysis (data set 03)
CURRENT and STORED
P229F09 NOx sensor 2 (cylinder bank 1) has a malfunction. There is a component fault.
CURRENT and STORED
rf065
Grossbritannien
Just get it remapped with an Adblue delete, the system will continually give problems that cost a fortune to fix.
I remapped mine after twice paying close to £1700 on repairs 2 years ago, not had a fault with the car since.
bladecrazy
bolton
tesla model 3 performance /honda cd175/w123 300d gertrude.
I think you have q1 which is now updated, to q3? i think, looks to be 2 faults , 1 nox and seperate adblue, the sensors need to be changed in pairs.
onefortheroad
uk.
Afaik new nox sensors run a different software package which would need to be done , you can't just swap them out.
Mercmebaby
Mercmebaby
Shammy1870!!
Okay thank you, so if I install a Q3 I need to install new software, Is that what you’re saying?
bladecrazy
bolton
yes unfortunatly or they cant operate.
bladecrazy
bolton
an independent with star can do the update , or fit q1s and no update needed.
