Nox sensor and exhaust
2016 CLS220D Shooting Brake AMG Line
Hi all, I have a 2016 CLS 220D Shooting Brake. The engine warning light came on and I have had the problem diagnosed as a Nox sensor failure. My local garage got a sensor in for me but cannot get the old one out of the exhaust. I have taken the car to a Mercedes specialist and they have quoted me £2640 to replace the centre part of the exhaust and Nox sensor. I wonder if anyone else has had this problem and how to get around this vast cost. This problem arose almost immediately after Mercedes recalled my car and updated the software. The car hasn't done 32000 miles yet. Of course Mercedes tell me it is nothing to do with the upgrade. Thanks
malcolm E53 AMG
You are not on your own quite a few members on here have suffered the same Nox sensor failures after the diesel emissions software update in fact a lot of owners won’t let Mercedes touch the car due to this myself included although I’ve just sold my diesel car and won’t be buying another. I’d do some research on here and go back to MB and ask for some goodwill you are ‘not the only one’ this is a known problem and you are being fobbed off.
ajlsl600
france
A well trot path of woe.
onefortheroad
uk.
Can the garage not heat it up and get it out , worse case scenario would be maybe helicoil if applicable?
Wire brush, plus gas for 2 weeks. Then maybe resort to the blow torch.
Patience is key to seized bolted fittings.
You go in ham fisted, you will round, snap it.
Tighten loosen in increments spray so on ans so forth.
davidsl500
Home : Derbyshire at the moment !
R172 250CDI Gone..!, R129 SL500 Gone...
There's always a way. If it won't budge, drill out, helicoil/re-tap or even drill hole in exhaust near sensor plug, weld correct thread nut on pipe and screw in sensor.. You need an old fashioned mechanic!
P
Just an update, A Mercedes specialist tried to get the Nox sensor out and failed. The car is now at the local Mercedes main agents and they tell me that they have a specialist they can call on who may be able to remove it. Now the news gets even worse as they tell me that Mercedes have changed the Nox sensors for a new type that are not compatible with the existing ones. So now I have to have both changed at £550 each plus £278 fitting each plus £250 for the specialist, and if the the exhaust gets damaged that will be another £1100 plus £440 fitting. they also charged me £122 for the diagnosis. So a failed sensor could end up costing me £3568. As soon as it is fixed it goes in PX.
bladecrazy
bolton
tesla model 3 performance /honda cd175/w123 300d gertrude.
thats crazy!
