O2 Sensor P0131 Merc C200
Sparky F355
Sweden
c200 kompressor
I have a Mercedes C200 Kompressor 2001 Saloon. I have been getting a P0131error code for the 02 Sensor. Low voltage Bank 1 Sensor 1. Could someone please send photos of where this sensor is located, or send my links. Even better any videos of how to change it. Also can someone recommend the best place to get replacement parts for this sensor etc..
Thanks you in advance
Mark Andrews
Hej Mark, do not forget that the MAF is the main reason for the 02 sensor to turn on the engine lamp.
Steve@Avantgarde
Bristol/Somerset
Firstly the O2 sensor is in the exhaust downpipe, you will need to get under the vehicle to change.
I would also unplug the cam magnet at the front of the engine and check for an oil leak into its wiring plug. If there is oil there, check the MAF as Malcom has suggested and then go to the engine ECU and check for oil there too.
If there is oil there, clean out the MAF, engine ECU and replace the O2 sensor. You may find you will have to repeat the cleaning process about 3 times until the loom is fully clean.
Sparky F355
Sweden
c200 kompressor
Hi Guys
Thanks for the information. However I am a bit a of newb when it comes to this. Can anyway send photos of the parts I need to clean like the MAF, and where the cam magnet is. Does anyone have any videos or photo's on how to do this kind of work.
Do you know where I can purchase a new O2 sensor as well
Cheers
Mark
You will find the MAF at the far end of the air intake box, the box fits over the MAF.... you need to do this first, you can even unplug the connector on the MAF and see if it runs better, if it does, replace it,
Sparky F355
Sweden
c200 kompressor
Please see attached photos. Can you confirm I am looking in the right place.
Cheers
Sparky F355
Sweden
c200 kompressor
Is this the offending part
Can you confirm if this is the offending Lambda Sensor which I am receiving the P0131 error code.
Cheers
Mark
Cheers
Mark
Yes that is the O2 sensor.
The cam magnet is on the front of the engine.
The first picture you have put up is of a SAM cover and isn't the air box.
A large picture of the whole engine bay and we can point it out.
Sparky F355
Sweden
c200 kompressor
Hi Alexander
I have a new problem. I have exceeded the limit of data I can upload for the photos and I cannot see how to remove them.
Can I email it to you?
Cheers
Mark
Best thing to do is upload them to a picture hosting site Nd then post the link up here
