Oil additive
Gazwould
C250 CDI
Best one period would be inorganic fullerene tungsten disulfide .
rifiki
Worksop
CLK W209 W121190B
I don't think any manufacturers recommend oil additives.
Mr Hatt
Lincolnshire UK
E320CDI Sport S211 2009, CLS320cdi Sport C219 2006, CLK320 Cab W209 2005
The additive package that quality oil manufacturers use within the product approved by engine designers is very complex already in order to take in to account lubrication, oil movement, temperature consistency, materials compatibility, durability over a set time period, emissions and emission systems, with this in mind, using the correct Merc product should be a perfect match and one of the reasons Merc engines can do hundreds of thousands of miles with out fault, introducing a foreign body, no matter how well it is marketed can only do one of two things; 1/ Upset the intricate balance of a well designed quality product or 2/ Nothing! either is far from optimal.
M80
Derbyshire
Snake oil additive is very good.... :rolleyes:
As long as some one is holding the head while you squeeze it out. They can wriggle a bit and even bite.
Think of oil as being a recipe blended to create a product with desired qualities. A bit like a cake.
If you were making a cake would you put twice as many eggs in it and expect it to come out better?
Gazwould
C250 CDI
This is very true of zinc in the ZDDP .
Best kept under 1400 ppm .
00slk
Cambridgeshire UK
6 egg yoke sponge......Lovely with cream filling strawberry jam and icing sugar sprinkled over top just like my Mum used to make :D
Mr Hatt
Lincolnshire UK
It has been two weeks and I cant get that picture of you squeezing oil out of your snake from my mind, will it ever fade away, should I get help?
