BlackC55
One of the officail documents:
- Fault code P 0 100, P 0 170 stored in control unit -
Topic number GI07.61-P-004078
Version 1
Design group 07.61 ME-SFI fuel injection/ ignition system
Date 05-02-2005
Validity ENGINE 111.943 in MODEL 170
ENGINE 111.944/945/975 in MODEL 202, 208
ENGINE 111.947 in MODEL 210
ENGINE 111.973 in MODEL 170
Reason for change Incorporation in TIPS
Complaint
Fault code P 0 100, P 0 170 stored in control unit.
Blue smoke from engine.
Cause
In the vent hose between the valve cover and the oil separator the connecting pipe to the auxiliary air injector may be blocked.
This impairs the function of the oil separator at high engine loads and oil-enriched air is sucked in.
Remedy
Disconnect vent hose and check passage.
The clearance should be 2.5 mm.
Remove/install/replace vent hose if the clearance has been reduced or closed off.
WIS references
Document number Title Note Allocation
AF07.61-P-6001A WIS Referenz Complaint
Symptoms
Symptom
Power generation / Engine management / Engine running / runs unevenly, shakes
Power generation / exhaust system / Exhaust System Function / blue smoke
Parts
Part number Designation Quantity Note EPC Non-EPC
0000490948 Mass air flow sensor 1 X
1110181682 Hose 1 X
Operation numbers/damage codes
Op. no. Time Damage code Note
Operation text
0912352
Validities
Vehicle Engine Transmission Major assembly (1) Major assembly (2) Major assembly (3)
SLK 170 111.943 * * * *
CLK 208 111.975 * * * *
CLK 208 111.945 * * * *
CLK 208 111.944 * * * *
E Class 210 111.947 * * * *
SLK 170
Version 1
Date 05-02-2005
Complaint
Cause
Remedy
WIS references
Symptoms
Symptom
Parts
1110181682 Hose 1 X
Operation text
0912352
Validities
SLK 170
