Oil leak near Oil filter housing
Bluegrass
W210 E320 Avantgarde 2000
For a few weeks now I can smell burning oil in the cabin once the engine warms up.
Had a look and noticed wet oil near the oil filter housing and the belts.Does anyone know what parts I need to buy to fix this? From the images I've taken I can't be sure where the leak is from, just guessing.
joderest
ML270 2003
Are you 100% sure thats oil, looks more like cooling fluid, may be worth checking coolant level.
Bluegrass
Bluegrass
Cooling level is fine. Have needed top top up the oil twice recently.
onefortheroad
uk.
The oil
filter housing top is sealed with a big rubber o ring . you get them free with an oil filter cartridge.
Bluegrass
Bluegrass
The oil
Thanks. Will look into it over the weekend.
Never known the big o rings to fail.
Did you recently change the filter and forget to put one on or replace the old one and put ann addifional on. They are hard to see to the untrained eye.
Make sure you get an original filter from MB (fleece filter).
There are a few i rings to change in the filter cassette too.
Good luck
star
Reading
Smart + others :)
There are 2 seals on the oil cooler bolted to filter housing, one seal under filter housing and one seal under the plate shown. They all go hard and leak.
onefortheroad
uk.
Buy a tin of gunk spray and give it a good clean up and you may find where its coming from.
Bluegrass
Bluegrass
Good luck
The last time was a service by the Indi a few months ago so would assume he did it properly. Will clean it up on Friday to have a better idea where it's leaking from.
Bluegrass
Bluegrass
Had a better look today whilst the engine was running an the leak is form the left side of the engine. It was dripping on the manifold hence the burning smell and smoke.
Rocker cover gasket is the most obvious. Are there any other gaskets or O rings I should change at the same time?
Cam covers and breathers on these engines are a common leak point. I'd suspect that.
Bluegrass
Bluegrass
The leak was from this cover on the rocker cover as a result of blocked breather hole.Apparently there's no gasket for it so used silicon sealant.
star
Reading
Smart + others :)
You may have had leaking breather covers but the mess shown in the 1st pics won’t have come from breather covers, too far away
Bluegrass
Bluegrass
Yes the first pictures are near the oil filter housing and was the first thing I noticed. But realised that the cause of the burning smell was from the breather cover leaking oil on to the manifold.
Cleaned up the other one and will see if there is any leaks there.
star
Reading
Smart + others :)
Ok we can only coment on the pics posted, the front still looks wet.
Bluegrass
Bluegrass
You will need to remember , that on removal of valve covers not to get any old sealant in to the oil l ways
Yes I know. Spent nearly an hour cleaning it to like new condition using industrial grade paint thinner (really good stuff). My old mechanic friend was doing it and he is even more fussy.
