P0117 engine coolant temp sensor fault
ash1212002
Coventry
clk 200 coupe kompressor auto 57 plate
Mercedes c250 CGI petrol blue efficiency
Engine management light and fan constantly running, engine temp not increasing
I've had it plugged into the diagnostics, engine management light has cleared but fan is still running really loudly
Permanent fault code P0117 - coolant temp sensor 1 short to ground, engine coolant temp sensor 1 circuit low
It appears I have a faulty temp sensor, could anyone please provide the part number and instructions on how to replace the sensor
ajlsl600
france
Sensor or wiring to from if ur on icarsoft you should see temp if any info coming from sensor. I believe a failed sensor triggers fan motor on full time. Sensor likely located near statt or related pipework.
A
ash1212002
Coventry
It's pic 80 in the diagram which is separate to the thermostat, just need to figure out how to get to it!
ajlsl600
france
No idea suspect bonnet lever n mk one eyeball may uncover location. Can't be to hard
A
ash1212002
Coventry
Managed to replace the cooling temp sensor without having to remove any other parts to get to it, all working now :)
Part no A0009056102 purchased from Mercedes £17.88
Hopefully this helps someone else out!
ajlsl600
france
It's grand ur sorted and that sensor about the most economic I heard of
