P208027 Temperature sensor
West midland
Mercedes C250 Cdi 2013 Sport plus
Please help I have a fault code which is P208027 Temperature sensor 1 'Exhaust system' (Cylinder bank 1) has a malfunction. I have a w204 c250cdi and is does not pick up speed very good (eml on)
P2080 G3/10 (right O2 sensor,before CAT,cylinder 4-6) aging,used too long (P0133)
P2080 G3/3 (Left O2 sensor,before TWC[KAT]) Aging,period too long (P0153)
H
West midland
Thankyou for your reply very unhelpful. My car is at Mercedes now hope it doesn't cost too much....
turbopete
Spennymoor
im not sure how we should take that. we dont have the car in front of us with a STAR machine connected so difficult to say for sure. you gave a code which as has been pointed out above, usually points to a failed lambda sensor/lambda sensor (o2 sensor as theyre more often called) reading out of spec, lean in this case, which can increase exhaust gas temps. quite how you feel that is unhelpfulis, to be frank, a mystery to me.
im also puzzled as to why you would ask about this at 7.28pm, then state at 8.59pm that the car is with mercedes as every MB dealership i know of closes at 6pm at the VERY latest.
AMGeed
Poole, Dorset
S204 C180K
If you are in the W Midlands, I'd be taking the car to MSL in Birmingham, not the main dealer for diagnostics and repair.
Lord_Lucan
Bedfordshire, UK
No longer own a Mercedes Benz
You only get 15 minutes to edit your posts if I recall correctly but yes it doesn't read like it was a typo. I hope I'm wrong though...
John Laidlaw
Wirral
Land Rover Discovery 4
Nice if they came back on and explained themselves....
Mike1985
W204 C250 CDi
Hi, I’m new to this so apologies For hijacking this thread but I’m looking for some info relating to a similar engine code. A couple of days ago my OH txt me a photo with my EML on. I have a handheld laser OBD reader and I’m getting the codes P2080 - Exhaust Gas Temperature Sensor Circuit range/Performance Bank 1 Sensor 1
And P0546 - Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 1
Anybody got any suggestions?
Get a readout of the live temperature reading from the sensor.
Mike1985
W204 C250 CDi
I’ve tried but I don’t think my reader gives those specific figures unless I’m using it wrong. I have a laser 5091 EOBDOII/EOBD if anyone has some knowledge on one of these?
rukako
did you solve the problem i having the same problem , i delete the code then more or one week it cames again...
can someone help me?
Dean Fletcher
Penrith, Cumbria
Mercedes E400
Hi Rukako,
Which code are you getting?
Likely hood is you eed to replace a sensor. Also this is an old threat I'd suggest starting a new one oooh and welcome to the forum.
W212
Hello
i have the same problem
I try sensor reading with xentry
The reading of sensor B16/15 is 0c
I am not sure if the sensor B16/15 is the oxygen sensor
Any one find a solution for this error code?
There are two temperature sensor in the exhaust. This is the second one in the center of the exhaust before the center box.
W212
I find this diagram
