Parking brake adjustment on CLK coupe
B
bimilne
Can anyone let me know how to adjust the parking brake on my CLK 230k Sport. I believe you have to remove the rear seats to do this and am not sure how to remove them
Thanks :confused:
Ellsy Tanners
Mars
Hello, is your car a 208 or 209 chassis?
If its a 208 then through the wheels, if 209 then adjuster under rear seat after wheels!
Ellsy Tanners
Mars
That adjuster is a self adjuster and shouldnt need to be touched if working correctly.
B
bimilne
I think it is the cable that require adjustment as the pedal travel is quite long.
Do you require to remove seats to do this or can it be done from underneath the car
That is done by removing the seat, and through the hole
