Poor ride quality 1992 230TE
The Crooner
Woodhall Spa Lincolnshire
2006 R320 cdi
OK
Having solved the idle issues, its now onto the ride.
It steers fine, and there is no "rear wheel steer", but the ride quality on anything but perfect road surfaces is poor.
Tyres are brand new
New front anti-roll bar and bushes August 07 10k miles ago
Two new rear springs March 06 25k miles ago
Poor ride most noticeable on poorly maintained road surfaces with lots of ridges
The self-levelling suspension seems to maintain a stable ride height even with several bags of coal right at the back of the car.
Opinions welcome.
TIA
Tony
With the state of all of our roads Tony even my SL feels bad.
Why do not we get the long term unemployed to re surface them all
The Crooner
The Crooner
2006 R320 cdi
Malcolm
Because it causes endless delays which lead to road rage, and we can no longer afford the drugs bill to treat high blood pressure, so we have to get ours cars' suspension right.
Tony
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
What wheels & tyres are fitted?
I'd look at:
* front antiroll bar bushes (don't look, just replace them)
* front balljoints
* front lower wishbone bushes
* rear subframe leading bushes
* 4-wheel alignment
Then:
* rear suspension leg top mounts
* check bolts that attach rear suspension legs to the lower wishbone
* suspension spheres
* front suspension shocker top mounts
* rear antiroll bar bushes
Nick Froome
www.w124.co.uk
The Crooner
The Crooner
2006 R320 cdi
Merc 10 hole alloys 15"
205 60 15 Maxxis M1 tyres - I think they should be 195 65 but the rolling radius is identical
I'd look at:
* front balljoints
* 4-wheel alignment
Then:
Nick Froome
www.w124.co.uk
Thanks Nick, helpful as usual.
kth286
E320 Coupe 95
I would look at rear suspension spheres FIRST as when faulty makes the rear suspension go solid, hence you will feel every ridge/pothole.
Bolide
www.w124.co.uk
That's very true
Also the cars are quite sensitive to tyres. Hard tyres like Goodyears boom and rumble but softer tyres like Continentals are a lot quieter and smoother. Tyres with stiff sidewalls don't work well on them
Nick Froome
www.w124.co.uk
The Crooner
The Crooner
2006 R320 cdi
OK thanks
I accept the remark about tyres, but I think my issue is more fundamental than the difference between them.
Can someone please post a method of diagnosing no gas in the spheres?
Years ago I had a Citroen DS and had the spheres recharged, is that an option on the Mercedes?
Tony
The Crooner
The Crooner
2006 R320 cdi
OK
Today we jacked up the rear end of the car, and suspect that the upper shock mount bushes are worn.
Will someone please post the link to the Russian site for the parts, and please conrirm whether the lower mountings are also bushed or solid.
Haynes points out the two lower mounting bolt nuts, but doesn't tell you what to buy apart from the nuts if you take them to bits.
Tony
The Crooner
The Crooner
2006 R320 cdi
Of course
We checked the suspension, and came up with a problem which had been identified as possible by Nick, so will do the top mounts.
The other bushes look old and tired, bit like me, but there's no significant play elsewhere.
I did ask about testing spheres but had no reply, guess you test them by changing them then?
Cheers
Tony
Bolide
www.w124.co.uk
I chased a fault around the rear suspension on mine and changed the top mounts, rear subframe bushes & spheres. The cause of the clonking was loose leg mounting bolts but changing the spheres did make a big difference
W124 estates are very critical of suspension setup. When it's right they are blissful. Once you've experienced that it can be a continual frustration if it's not quite right
Nick Froome
www.w124.co.uk
The Crooner
The Crooner
2006 R320 cdi
Thanks Nick, and , er, thanks.
I've yet to experience blissful, but I think I know what to expect.
The answer of course is to be driven in a "blissful" car, and have the driver of it drive mine.
Think I need to get me to a meet and beg a ride.
Cheers
Tony
The Crooner
The Crooner
2006 R320 cdi
Today we did the rear shock top mount bushes - remove trim cover around wheel arches inside car, remove retaining bolts inside car, jack the car up and there is ample room to remove and replace the inner and outer mounts.
There's some old and new pictures below, but a marked improvement on the ride quality. I now have to resist the urge to replace all of the other rubber in the rear suspension.
Its off for an MOT on 20 Feb. Maybe then I can justifiably change some more bushes...
Tony
rhud
A160 BlueEfficiency Avantgarde SE 2010
That's very true
Nick Froome
www.w124.co.uk
Interesting. I've been around the web quite extensively looking for evidence re which tyres to go for re maximum comfort - which presumably equates to sidewalls with more give and (for lower noise levels) tread pattern.
Any other views/evidence/ experience in this regard would be most welcome.
Tel: 020 8863 9233
