Shadychris
- Jun 30, 2021
- '95 R129 SL320
Thanks for that - I did wonder about that myself. However I now have the self diagnosis N22 AC controller info and have worked through that. Other than an error 70 for the aux pump 'open circuit' which persisted a couple of times but has now cleared after fiddling with the connector, I have no DTC codes stored. Im not getting an error 73 for AC pump signal.Your problem is likely with the RPM sensor on the compressor, or the wiring to/from it (devoid of any insulation?) The ecu sees no compressor rotation and disconnects the compressor for safety.
Wiring harnesses look to have been replaced with insulation in good condition.
Next step today is to knock up a blink code reader and see what error codes I have on pin 16 of the 38pin BM module..
