R172 SLK alarm keeps going off
MBNuB
Hants
www.gyrocopterexperience.com
W204 220CDI R172 SLK
The alarm on my wife's SLK has gone off unprompted twice in the last couple of days.
Is there anything I should check? Or do we need the dealer to check it out?
We're about to go on holiday and don't want to infuriate the neighbours while we're gone.
No windows/doors left open/ajar. Any ideas?
Check for dust in the interior sensors if you have them. Also check the battery - if they get tired they can trip the alarm.
If you're concerned just disconnect the battery.
A moth or a flying bug is a common cause, you can disable the interior motion sensors (should be a button with a radar type wave symbol on it inlaid in a picture of the car). On a previous car air blowing in through the vents also caused the alarm to activate at the most inopportune times
MBNuB
MBNuB
Hants
Thanks chaps.
I think the battery is OK but I'll stick to on charge to be sure.
I'll have a look at the sensors, if I can find them, and see if I can identify the interior sensor button.
Many thanks for your input.
mioba
Nottingham and Köln
Could also be a sign the siren is failing. It’s located under the front wheel arch. Wheel and liner out job to replace.
www.W140.co.uk&www.r129.co
