R230 AC condenser
flowrider
SL500 (R230)
I need to replace the AC condenser on my 2004 SL500, any recommendations on good makes welcome.
Never had any issues with Nissen and they're reasonably priced too.
I have A2205001054 for all non AMG Black Series irrespective of age or 350 or 500.
Checked both versions of EPC I use and get same answer.
flowrider
flowrider
SL500 (R230)
Thank you, looks like the condenser is going to cost about £100 with delivery. Do you know if this is a DIY install?
Not sure but can't see why not (aside from needing it professionally regassed at the end).
I did a Saab one with no issues on my own.
You may need to remove the radiator as part of it.
wizzman
Grimsby, NE Lincolnshire
SL500 2002
And you will need Star to re set the A/C system I seem to remember on mine. I had a Valeo one fitted. Paid an independent to do the job because it had to be re gassed and re- set
flowrider
flowrider
SL500 (R230)
An indy is an option if I can get it all done for under £300. The compresser is £100, a regal is £80, so maybe a couple of hours labour should do it. I will have to google for instructions and see how it's done.
Change the dryer as well.
Be warned, it can be a PITA to seperate the rad pack on an R230.
