R230 CD Changer
Kirbs
Sutton Coldfield
ECLASS 280 sport,2009,3.0 and SL350 2004
My 6 CD Changer in my R230 SL 2004 Will not eject. It makes the sound as if it is,I have done all the usual things to try and free it including shouting at it but it wont budge
Any ideas folks?
Cheers
Sounds like it's either got s disc jammed or faulty. I suspect you'll. Need to remove the unit.
AndySlade
Tadley, Hampshire
C220 Diesel Estate, Sports Edition
I had same problem and as suggested by Malcolm I removed and replaced fuse and it sorted itself out. Certainly worth a try.
K
Kirbs
Sutton Coldfield
Thanks ,will try the fuse route first and come back
Cheers
peterws1957
Lancashire
Cheers
It's a common problem. Press the eject button and at the same time give the cartridge a sharp rap or two with the handle of a screwdriver or similar . Keep doing it and the cartridge will pop out. It's a problem with the lube in the player drying out.
K
Kirbs
Sutton Coldfield
Thank you,this method worked first time and I didn't have to shout at it
Was worried about my led zep collection being lost
Thanks for the help and the whole lotta love!
Cheers
AndySlade
Tadley, Hampshire
Cheers
Glad it is sorted, I found like most things it pays to use it and eject cartridge often. Good excuse to change CDs! I bought two spare cartridges and am constantly changing for new CDs I buy? Search part no. on cartridge and search on eBay for a spare!
peterws1957
Lancashire
Cheers
Ah yes the old shouting at it method. Use it frequently:)
