R230 Roof flap problem
STEc74
St Helens,Merseyside
My car SL 350 05,sons car CLK320,other cars BMW 318IS ,95, 1964 Chev Corvair Monza restoring.
Hi, not been here for some time, I have a problem with the small flaps to the roof on my R230,i was out today with the roof down enjoying the sun,i noticed the small flap was sticking up at one end and when i lifted it it came away in my hand ,very lucky not to loose it, on closer inspection i found the little clips that hold it down had broken the spring is still in place,
Has any body had this problem and is it an easy fix.
flowrider
SL500 (R230)
This is a known issue, do a search on Google and you should get a hit.
STEc74
STEc74
Thanks for info, will give it a go
flowrider
SL500 (R230)
I think there was a fix tutorial on mbworld.org
Dave779
Burton on Trent
Mercedes SL350 2003 and Nissan Qashqai 1.2 Tekna 2016
I had the same problem and fixed it temoraraly with 2 lots of sticky tape with give enough to allow it to go vertical, and then stuck a pice of elastic in the middle, very tedious job to bring it back down. But after a few months I had to buy a new one at around £260 and £30 to fit as it really anoyed me. Keep looking on ebay and scrapyards but these are like rocking horse poo second hand.
STEc74
STEc74
Hi ,sorry for late reply,got in late,there`s none to be found on ebay,i will make repair until one comes available,not paying those prices unless i get desperate.
star
Reading
Smart + others :)
Fixed a customers with a small cabinet hinge.
star
Reading
Smart + others :)
Still can't find black anadized hinges. I'd better do the o/h car, it's only been like it for a year.
drmw
Yorkshire
www.autonomed.co.uk
I fixed this on one of mine with the tube from a BIC pen cut to the three or four lengths, a length of coat hanger wire as the hinge "pin" & glued alternating lengths to each side - doesn't explain it very well, but if you visualise it makes sense. What I didn't have then but do now is some of this http://qbond.net/ - used with the powder this sets in a few seconds and is incredibly strong.
John Laidlaw
Wirral
Land Rover Discovery 4
Wonder if the Black polyamide (Nylon) ones would work Ian?
STEc74
STEc74
Fixed my flap today with the wire technique,thought about using a tube to fit over the pins and then sticking them to the broken clips but thought this would not last with the spring being to stong,i had to take the top cover off to properly secure the wires around the pin and retaining clips,took approx one hour,
now woking perfecly,opens and closes as it should, I`ll be keeping my eyes open for a used replacement top cover.
A4DJL
Edinburgh
SL350/2004/3724
Pardon my dumb question, but what does this flap actually do? I have just discovered that the nearside flap on my 2004 SL350 has disappeared! No idea how or when this happened. Other than aesthetics, is the missing flap going to cause functional problems? The roof seems to go up and down OK. I guess replacing the flap (or more likely the whole panel) using Mercedes parts will be a very expensive exercise.
Any advice would be much appreciated.
David
John Laidlaw
Wirral
Nice one, glad you're sorted...
STEc74
STEc74
  • #19
The flap is nothing more than a cover to tidy things up when top is down,this will not cause any functional problems just looks untidy when not inplace,i beleive a new cover complete with flap will set you back £250+ probably why we repair rather than buy new,M B should have recognised this problem and rectified it.
A4DJL
Edinburgh
SL350/2004/3724
Thanks for the re-assurance. I guess I can live with the untidy look in this good weather until I find sensible priced solution
David
