Conor
- Jan 22, 2019
- Location
- London, UK
- 2010 S212 350 CGI // 2004 R230 500
Hello and good evening all
As part of my R230 ABC overhaul, I've just started rebuilding the valve blocks.
I'm using the XR8 rebuild kits and have an issue with the size and fitment of the larger o rings, which seal the solenoid from the outside elements.
Has anybody had any issues like this ?
If you look at the following XR8 install guide, look at R5 and S1.
One of them is a regular o ring that just seems slightly smaller than the one I removed and won't sit properly, rather one side pops up when you push in the other side.
