radio audio 10 cd - need radio code
D
dazyp
had the battery disconnected yesterday and when i went to put the radio code in i could not find anything in the handbook or in the audio manual
it says there should be a card with the code on but this is not with the vehicle ?
is there any way i can get the code
the rdaio says mercedes audio 10 cd looking at other pictures inthink it is the alpine model
thanks
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
MB can tell you I believe providing the stereo has,nt been changed in the car.
Do a google search for "mercedes car stereo code" and/or variations of this, and there are web sites that will tell you the code. example below, most make a small charge.
http://www.instant-radio-code.co.uk/?gclid=CKqpz8C67JUCFQFbtAodb2ACYA
You could always remove the head unit as sometimes, if the head unit has been replaced at some point it may have the code written on the casing, as both mine were sourced from scrapyards, the codes were written in marker pen on the outer case.
bigasotonuk
Southampton UK
If you post your car stereo serial number, I have just found I have a key code generator I downloaded, I maybe able to supply it for you. Its meant to work very well though I have never tried it.
D
dazyp
model number - mf2910
serial number -AL291010932300
thanks
bigasotonuk
Southampton UK
Well I have just run the code generator, you did,nt say wether yours needed a 4 or 5 digit code but try these, I hope they work for you please let me know how you get on.
4-digit, 2772.
5-digit, 12332.
D
dazyp
it is a 5 digit code
the above code did not work ?
bigasotonuk
Southampton UK
Sorry it did,nt work I,ll have another look it maybe me not using the software correctly.
D
dazyp
ok will ring them on monday thanks for the advise
bigasotonuk
Southampton UK
I,ve tried another code calculator again, try 52772
whitenemesis
CLS55 AMG '05
Call into you local dealer. If the unit is original they can tell you the code in about 5min. :)
D
dazyp
spoke to dealers today and they gave me a code for radio , i gave the the vin number , model of the radio and the radio serial number which they then gave me a 4 digit code ? the radio is asking for a 5 digit code and will not except it , mercedes then said thats about all they can do and to try a car audio shop to try and decode the radio ?
any thoughts on this ?
Jay Gee
N.Wales
Honda
That's strange,because when I had a problem with my Audio10, the dealer gave me the code from my VIN,and when the unit refused to accept it,entered the serial number into the system,gave me another code,and also told me that it wasn't the original radio for my car.It didn't accept this code either,but it turned out to have a terminal problem (as in it had died).Might it be worth trying another dealer?Edit-Itook it to a car audio specialist who said that Alpine and Becker both produced this model for MB,and if it was a Becker,there would be a good chance to sort it.Alpine UK apparently do not provide any back-up???.Guess which one I had!
bigasotonuk
Southampton UK
Sorry the codes did,nt work, first time i had used the software, so was,nt sure if it was any good.
I bought a Audio 10 radio/CD unit from a local car audio shop i went to fit it and the code they gave me did,nt work, took it back they sent it away to a repairer it was back within the week with a working code.
Try your local car stereo shop it should,nt be a problem, if for some reason you can,t get it sorted i do have 2 Audio 10 units, 1 is a radio/cd the other is radio/cassette, both with working codes, that i could be persuaded to get rid of.
D
dazyp
thanks will give the local audio shop a ring
whitenemesis
CLS55 AMG '05
Old trick...
Place radio in poly bag in a freezer for 24hr, erases the code.
Might not work on more modern units though.
Paul Okeugo
Abuja, Nigeria
Car radio code
Hi guys
I am very pleased to have found this site.
i have a similar problem with my c220 2000 model.
The batterry was touched and the radio needs a code that i dont have.
I am desperate for advice!!!!!
also engine changes noise when AC is on. is that normal?
and whats the contact for mercedes.
HELP
Hi guys
HELP
For the radio code just go with the car VIN number to any MB dealer,, yes the engine will alter slightly with the air con on
