Rear Brake bleed nipple C class A205
L14m
C 220d cabriolet A205
Hi can some one help in what size the bleed nipple is on a 2017 C Class Mercedes cabriolet A205.
Liam
DREAMER NO2
W124 2.6E M103 1989
Liam just checked for you, and there are a few models to choose from , and to get the bleed nipples right i would visit the Mercedes dealers with your vin number . They wont cost a lot, and you would be sure they will be the right ones .I use - ask seller a question they will get them for you https://www.ebay.co.uk/str/mercedesandsmartnewcastle
L
L14m
Cheers for the quick reply. I'll give them ago.
Ivanhoo
R129 1998 2.8
I bought a set for your w202 yhey where 8 pound each couldent get yhe Suze anywhere else had to be dealer
DREAMER NO2
W124 2.6E M103 1989
When you remove the old nipple , use a good fitting drill bit in the bleed hole to give it strength it stops them shearing off .
