AdamG
- May 24, 2009
- Location
- Bromley, Kent
- S320CDI (2003)
My Bosch high pressure CP3 fuel pump was leaking slightly so I bought a seal kit F00N201973.
There are several variants of the CP3 pump so some of the seals are not used.
First I stripped the pump down. There are six bolts holding the steel pump body to the aluminium back plate. As I did not plan to touch the high pressure side it is vital to keep all dirt out. The high pressure part consists of three pistons that compress the fuel and achieve this by very tight tolerances.
Once I had stipped and cleaned the low pressure side I began reassemble.
First the pressure relief valve oring
Next the fuel temperature sensor. There was no copper washer in the kit for this so I had to reuse the old one. I also put the large oring on the raised circular machining to the right of the sensor. (not shown in the photo)
Next the orings for the quantity control valve.
Next the seals that seal the high and low pressure sides. I put some silicone lubricant on these to help reassembly
Then bolted the six bolts up
