refusing kickdown
range rover
Northern Ireland
E Class Blue EFFICIENCY 250 CDI Sport 2013
Out for a drive yesterday, went to accelerate, there was no change down, I flicked the shift lever to the side and 4 popped up indicating a change down, by this time I didn't need to speed as I was coming to a shop. After I had stopped and then started about 10 minutes later, I started off like an old boy racer! The changes were perfect and have been since, what the heck was going on ?
R
range rover
Northern Ireland
Have you tried another kick down relay?
No I haven't, I think it must be electrical as it cleared after I stopped at a shop, it hasn't done it since. I think I will just play it by ear, if it does it again I will look into it much more, and I will keep you all informed.
bembo449
gainsborough , lincolnshire
I think the general advice for box issues is start with a fresh filter and oil if you don't know when it was / ever been changed , unless you get a permanent problem where it can be plugged into and the codes can be read
R
range rover
Northern Ireland
I change the transmission oil every 40k, at the moment it is near the change time again.
R
range rover
Northern Ireland
Well, the problem seems to have been the EGR, apparently the computer said something along the lines of too much air, seems like there was a seal that needed renewed, there is another which the garage did not have a replacement for so it was a case of try it and see if that is any better. It was intermittent anyway, but so far no problem, happy days!
R
range rover
Northern Ireland
Spoke too soon, it has come back to haunt me, fault codes point to the EGR valve. Just noticed I should have this in 'Engine Drivetrain Fuel and Exhausts, in my case I have fault codes.
Chrishazle
Nr Ashford, Kent
When I had no kickdown with my S203 C270Cdi, along with not being able to rev above 3k, it was the MAF. Thankfully car was under warranty so changing the MAF cost me nothing, but it cured the problem!
R
range rover
Northern Ireland
Well, hopefully the indie read it right, I will update when I get the new EGR fitted .
R
range rover
Northern Ireland
Well, a new EGR was fitted today and it seems to have solved the problem. Sometimes I felt the gearchange was harsh, I suppose one would say it snatched, that has been eliminated too.
mattkh
England
A160 W168 1999 1.6
What is the mileage.
If you have the old EGR, please put up a picture. Thanks.
R
range rover
Northern Ireland
The mileage is 160k. Unfortunately I do not have the EGR. Interestingly I was talking to a customer when the EGR was being fitted and he told me about a company who does remapping etc, I don't know what the cost would be to bypass the EGR, I did ask my indie a year or so ago and they said that they didn't do that. Had I been speaking to that customer a month ago I probably wouldn't have fitted a new EGR, but there you go. The EGR itself was £264, I think the customer said a remap was around £500, but I don't know what that covers.
R
range rover
Northern Ireland
I should add, at my age an improvement in MPG is of more interest than burning off someone at the lights, although that can be handy at times too!
