Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
to remove the front disk, WIS says undo the wheel rotation sensor bolt and withdraw the sensor and the bracket. This bracket holds that sensor wire and also holds the brake line.
Is this just to free up the flexible brake line?, as it says don't disconnect the brake line.
This would be useful in attempting to replace a piston dust cover.
There is a link on how to remove the wheel rotation sensor, and it starts with undo the electronic coupling and free the cables. I assume one does not have to do this, when just removing the disc.?
