replacement DA pads
Capra
Gloucestershire
W204 2013 C350 CDI Pan roof
I have a cheap DA polisher and would like another pad, I can probably pick up additional pads that Velcro onto the bit that fixes onto the polisher, but can you get replacement adaptors so that smaller pads can be used.
Capra
Capra
Gloucestershire
A plethora available from HERE, along with more pads than you could ever use. :)
Thanks, good choice there. So as long as I pick the correct adaptor for my polisher and can I with a different size as well.
Submariner1
Windsor Berkshire
CL500 2009 5.5
Good point,
I wanted an adapter that connects the Makita, big M14 thread with 2 flats, that the backing Pad is bolted on with a single bolt going through the backing pad to the 3M quick release system.
