Replacing W140 Coupe Bonnet badge.
jibcl500
Cambridgeshire
CL500,ML55,SLK280
As above, does anyone know how this is done, I cant see anything under the bonnet even directly below the badge that looks like I can remove it.
jib
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Got it sorted. I removed the bonnet catch, there is a small hole and I could just see the pins on the back of the badge, using a blunt tool I pushed on one pin, there is no access to the second pin.
This moved the badge 2-3mm creating a gap, using my T shirt in a saw action into gap and then lifting allowed the badge to spring off.
New badge fitted job done.
jib
