Retrofit NTG4.7 comand online
Marcio Ota
W176/2014/1.6
I'm trying install a HU comand (NTG 4.7), but the GPS don't fix !
Already install this parts:
Can't I plug the GPS antenna directly in HU ?
John Laidlaw
Wirral
Land Rover Discovery 4
Welcome- can’t help with all that electronic stuff, that’s a job for Comandonline
Alfie
Surrey/Cotswolds
www.comand.co.uk
Have you run initial startup in Xentry?
The easiest thing for the GPS is to plug it into the head unit and mount it under the instrument cluster on top of the speedometer/rev counter.
Marcio Ota
Marcio Ota
W176/2014/1.6
What i need to set in Xentry?
When I put it with short cable (20cm) it appeared in the 'engineering menu' SHORT.
So I put a 1m cable, it was ON.
But it does not fix (0/12 satellites)...
Alfie
Surrey/Cotswolds
www.comand.co.uk
You need to take the car to someone who has genuine Mercedes Xentry and ask them to run 'Initial Startup' on the comand system. This is not something you can do yourself.
Use a genuine Mercedes GPS antenna and then wait for it to find satellites. This takes about 15 mniutes.
