- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
- Thread Starter
- Thread starter
- #61
Thanks could you simplify please. What do I do
Do you have the correct little box for the running lamps, there should be a ground lead that goes to any nearby grounding point.
You will have an "ignition" wire that you connect via a piggy back fuse to fuse 27. You remove fuse 27, plug in the piggy back fuse holder and replace the fuse, and your ignition on wire connects to this piggy back fuse..
You should have a third wire, this is to turn the running lamps off when your lights on turned on, you just join this wire to one of the live parking lamp wires.
