if its one side only it could be a link inside the light unit. A link between the actuator and the reflector may have fallen off. Std failure on Omega xenons. replace lamp unit or split apart and glue the bits back together. Never did on mine but on omega's a bloke in engineering shop made up metal links to swap out the designed to fail plastic originals
