S320 LWB Power Steering
rutland-boy
Hi All,
A newbie question, I would like to check the fluid in the Power Steering as there is a slight noise when I turn the wheel.
BUT where is the reservoir to do this ? Does it have a filter, can I change this, should I use MB steering fluid or another brand ?
Chris
Hi Chris and welcome,,your S class what car is it 140,220, or 221
R
rutland-boy
Sorry newbie mistake it is a w220, thanks
Cole@MBS
www.mbssouthampton.co.uk
Right hand side of the engine as you look at it, just behind poly v belt, black screw on cap,only thing there!
R
rutland-boy
Brill, got it, checked it.
Now have another question (!!) sorry if its already been asked on the forum
Small dipstick, with several marks (i ithink) 20 (min/max) and 80? (min/max).
Min is just about on the lower min (20) just about where round lower end of the dip stick is. Where should it be ? (i'm guessing this is about ambient temp but not sure).
If I do need to add fluid, what should I add. Is it 'normal PAS' fluid or should I wait for MB to open tomorrow and get some from them ?
Any tips for filling it up, on a range rover I had previously you were meant to turn the wheel from lock to lock after filling it to the right level, check it again and fill to the right level.
Worried about doing this when its making its current noise as it might put more strain on the pump in my opinion.
As usual thanks for any help.... Brilliant response.
Cole@MBS
Check the level when the car has just had a run, it should then be just off the highest mark, the 20-80 are temp marks and the level should be on the marks according to the temp of the oil!
R
rutland-boy
Great will do it later today.
Any comment on the fluid if I need to add some ? MB or other make ok ?
Thanks in advance.
Cole@MBS
No, stick with the correct mb stuff, then you know its right!
R
rutland-boy
Thanks for all the help.
will stick with MB as suggested.
R
rutland-boy
Just checked after a drive to the local town and the level hasn't moved at all :shock: !
So I will definitely get and add some tomorrow.
Anyone have any idea how much I will need ?
1 liter is the normal size bottles
mr. shr
Cambridgeshire
W221, W166
Get a 1 litre bottle and then I would add 0.1 litres at a time. (There should be markings down the side of the bottle).
I did this recently on my Mum's W211 (was making a really unhealthy noise, like a very high pitched screaching sound that sounded like something very very serious.)
Anyway, I added 0.1 litres (of ATM fluid on a W211) and the sound completely disappreard.
So I would add a small amount and test it, prior to adding any more. I wouldn't just add the whole bottle in one go.
Tel: 020 8863 9233
