RobWheatley
- Aug 26, 2010
- Age
- 57
- Location
- Chatham, Kent. UK
- 2002 S320CDi Auto with Toys...
Hi All
Had a look around but cannot find any info on my problem.
2002 S320CDi, when starting from cold the High Pressure pump at the front of the engine leaks (at a fair rate onto the belts etc), when it warms up the leak seems to stop, its leaking from the very top plate (at the mating surface) is this something that can be repaired or is it a new pump?
If it can be repaired are there seals/gaskets that are needed or can it be done any other way?
Is it easy to remove to replace/repair it?
Rob
Rob
