S350 (2011) vibration
davsop
Midlands
S350 Bluetec 2011 w221
Hi everyone
Just back from a trip yesterday and noticed a heavy vibration when reversing or going forward at low speed.
Mobilo just arrived and think it could be either an engine mount or gearbox mount.
Anybody else every had this problem? Is it an engine out job?
Dave:)
LPGJOE
Tavistock
06 320 S class CDi
Hi everyone
Dave:)
Had this starting on mine (320) turned out is was the prop shaft mount that was worn, also the rear rubber joint between shaft & back axle was starting to get brittle.
davsop
davsop
Midlands
Thats interesting. I'll post the answer as soon as I hear back from the garage.
davsop
davsop
Midlands
Just received car back. All sorted. Engine and gearbox mounts replaced. Total £658!
LPGJOE
Tavistock
06 320 S class CDi
Wow thats a lot for mounts ! Must be a difficult thing to do, bet someone will say that was a bargain !
davsop
davsop
Midlands
I thought so as well but even an indie was quoting £600ish. And of course they're given me a list of another 5 or 6 jobs that need doing but I'll get my local garage man to do those as they're more run of the mill!
LPGJOE
Tavistock
06 320 S class CDi
Typical cars Mate go in for one job and get a list of others, what were the other problems nothing to costly ??
davsop
davsop
Midlands
Wheel bearing needs adjusting.
2 x Spring link arms.
Brake pipes showing corrosion at rear, Axle needs to be dropped.
Rear propshaft coupling needs replacing as showing cracks.
Rear suspension bellows are perished.
Besides that perfect!;)
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Thats a lot of work for a 2011 car, what sort of milage?
davsop
davsop
Midlands
115k and I've had it since new. Services on the button every time. It goes to show that whatever you do things are designed to wear out these days!
LPGJOE
Tavistock
06 320 S class CDi
That prop shaft coupling is what i had done, get them to do the front mounting as well bet it has some play in it, wheel bearings probably just need tightening up , seems to be a common fault, But the rest ! looks like another big bill, most seems to be on the rear. , Good luck, maybe you can sell the wife,
davsop
davsop
Midlands
Ok thanks for the advice. I won't tell the wife what the plan is.:)
www.ckinsurance.co.uk
